Hello-
I have this evening come to move my Z4 out of the garage after its winter rest (since early December) and having started fine (having been started a few times in the intervening period and been on trickle) I've found that the car simply will NOT move.
I had expected the rakes to be ceased a little but even heavey 'acceleration' and reversing is not budging. The car rocks fine so power is going to the wheels, past the diff.
The car will rock on the wheels and I've jacked it up and the wheels will turn about 4cm but then there is a knock and no further.
At first I thought the diff had locked somehow but why? Then I relasied this is very similar to how the car rocks after you have applied the handbrake. So, my thinking is that the handbrake has ceased on the rear wheels. With the handbrake on, there is no change.
I had left the handbrake on for about 3 weeks before I thought it would be better off.
So, how do I retract the brakes? How do they work on the Z4? I am guesing there's a pin or something similar. Are they within a drum in the hub?
Very frustrating as I was looking forward to getting out in it this week!
Thank you!
Thank you!
