minibbb said:The handbrake needs tightening up on my coupe as the car rolls unless I crank it up super high. Is this any easy job, I.e a cable that needs adjustment?
bcworkz said:fixit man, while the anchorage is similar to a 330, that's not where you adjust a Zed. To access that anchorage, you do have to drop the prop shaft as suggested in scousefly's link. But that's not where you adjust a Zed's handbrake. I've posted about this before.
cj10jeeper said:Save adjusting the handbrake until you swap the discs. Chance are if it's out of adjustment they will come off anyway. Once you fit the new discs there drive 100m with the handbrake on to bed in then adjust them up through the bolt hole.
Dead easy if fiddly and I've done it a couple of times without ever needing to touch cables.
