Handbrake failure
TommyGG
Hello!
e85 '03.
The person I bought off told me the handbrake is fine, but needs to be pulled firmly.
I pulled it hard a couple of times, and the whole thing made a pop sound and seemed to have popped off! It popped back in again though, and seems OK.
However the other day I had a handbrake failure and it was lucky I spotted it. I parked on a gradual incline hill, put the HB on and the car very slowly started rolling backwards. I always park in gear now just to be safe.
Sometimes the handbrake seems to work OK and I can only pull it up a couple of inches, other times it feels loose and I can pull it much further. It seems random on each HB usage.
Anyone know what this could be? Might the cable need tightening/replacing?
I have this exact same issue, my driveway is on a steep hill and pulling all the way to full lock doesnt even stop the car rolling back. I have to park, put in first gear and then pull with both hands hard to get the car to stop safely... Might mean previous owners wore it down too much?
Mines a bit tricky. I applied it the other day, got out, opened the garage door and felt a weight against the back of my legs.
Then spent 30 frantic seconds trying to figure out a way to stop being squashed between the garage door and the Z. Luckily the car seemed to settle and I could squeeze through a gap. Would have been a poor way to die, ran over by a stationary sports car...
German engineering my arse. :oops:
if your 2003 Z4 has SMG transmission, before shutting off the engine, you can put it on 1st gear. It wont break it.
(same concept as manual transmission, two supports - transmission lock and handbrake) :driving: :thumbsup:
But I still suggest have your handbrake level, handbrake cable and brake shoe check :)
If its only minor maybe a mechanic can adjust your handbrake lever pull count..
