Haltech IC7 :)
IAmOrion
Cambridge, UK
I really like the Haltech IC7 digital dash and wanted to give one ago. It doesn’t work out the box at least for my 2003 as there’s no can bus lines on the obd-II port.
There is, however, can lines behind the dash as well as kbus.
So one custom pcb designed and fabricated later ... and then programmed ... I have a fully working Haltech IC7 😁😁
mr.tourette said:
looks good :thumbsup: are you going to be able to live with the fit? or do you plan on tidying things up somehow
Defo tidying it up. I’ll be 3D modelling and printing a mount and a way to fill the gaps so to speak :)
Awesome..excellent bit of modding, looking forward to seeing the end result :thumbsup: You've knocked 10 miles off your car btw :D
Ha I know - it’s where I used the car without the digital dash fitted to run some errands. It matches now :)
Sure gives a bunch of info at glance but it's not for me. I like the look of the stock set-up. But as mom used to say, "to each his own." I do look forward to seeing what you can design and print to have it fit in cleaner.
