monkadill said:Jonny, why have you sold these?
Just asking as I'm paranoid the drop on the Z with these springs make the car impractical?
Bad_Pritt said:-35mm is pretty low but I think its doable. Any lower than that will give you rubbing issues. Lind you -35mm is probably the drop as to standard suspension, if you already have M-springs, the additional drop will be about 25mm.
I've had à 40mm to 45mm drop with springs and that was really bad.
Many Zeds on here run H&R's and as far as I have read, all good reviews![]()
monkadill said:Bad_Pritt said:-35mm is pretty low but I think its doable. Any lower than that will give you rubbing issues. Lind you -35mm is probably the drop as to standard suspension, if you already have M-springs, the additional drop will be about 25mm.
Thanks Brad_Pritt thats the reassurance i was looking for. So my drop is only 25mm and its 35mm on non M's.
