The fronts may need shorter droplinks in some cases.
Not much, maybe 5-10mm or so.
This also depends on what shocks you use, but the end tips of the e46 m3 antirollbar are slightly differently bent than the stock ones on the e85.
So they're not 100% exactly the same shapewise.
On stock shocks this is not a problem, but most coilovers lower the lug on which the droplink is attached, so in these cases it can be a close fit (rollbar hits the control arm in full droop, which can cause serious damage when not noticed!). (the question is, is this a shock thing or a rollbar thing )
Considering the front OEM roll bar fits I'm not sure if your right, especially as I was about to install one but saying that I didn't and opted to get one from hr specifically for my car.
So I can't say you're totally wrong as I never tried.
With the combination of an H&R E46 M3 front ARB and KW Clubsport coilovers, shorter droplinks are definitely required or the ARB fouls the brake callipers on full lock. The standard droplinks are fine with stock shocks and Eibach springs. There are no clearance issues with the M3 ARB with either suspension setup at the rear on the Z4MC.
