H&R and Bimecc Wheel Spacer Clearout - 6 Sets
gwatson
 Aberdeenshire
Evening all,
Time for a garage clear-out. All prices exclude P&P, can be collected from Aberdeenshire, or any set shipped for £6.50 (excluding insurance). Only Bimecc spacers come with extended wheel bolts, couple of sets available at the bottom.
All pictures below in order of listings:
Spacers:
1) H&R 107525 - Grey - Total track width increase 10mm, 5mm per spacer. £20 - Pending Payment
2) H&R B2075725 Black - Total Track increase 20mm, 10mm per spacer. Boxed £50
5) H&R 2475725 - Grey - Total track increase 24mm, 12mm per spacer. Boxed. Been sprayed black, look good once on the car. £50
Extended Wheel Bolts:
20x M14 x 1.25 Extended wheels bolts, including 4x locking wheel bolt (42mm of thread) £25 (all modern BMW's)
Hi. I'll take these. H&R 2075725 - Grey - Total Track increase 20mm, 10mm per spacer. £45 - PM sent..Thanks
i would take the 24mm and 10mm. do you know if the standard e85 bolts have enough meat on them? Im based in stonehaven so could collect seeing as your Aberdeenshire(saves time with packing and post office etc). If the 30mm fall through then i would take these instead of the 24mm.
Hi.
Will be in touch, the chap above is looking for postage to New Zealand which may be cost prohibitive. I would definitely recommend longer wheel bolts for anything above the 5mm.
