I have a drive which slopes downhill from the edge of the pavement to my garage. The underneath of my 2015 E89 scrapes noisily every time I cross over the hump at the top (temporary fix is to place a piece of old carpet there each time I come or go). I'm in touch with the highway department to see if I can get the high edge of the pavement lowered a bit. This afternoon I decided to check the clearance, which I think should be 130mm. I don't have an inspection pit so it was a bit of an arm stretch whilst laying on the garage floor. The exhaust pipe is approximately 130mm above the ground but there is a plastic cover closer to the passenger side which bulges downwards at its rear edge and gives a clearance of approx. 105mm. I do not know if this piece is supposed to be curved, whether it has sagged with age, or is not fitted correctly. As I live 350 miles from the main dealer I bought it from it's not going to end up on their ramp any time soon!
If anyone knows whether the plastic panel is supposed to be flat or curved I would appreciate the information so I can sound a bit more informed when I phone the garage. (You may answer from memory, or if you are incredibly kindly disposed, after laying on the floor and having a look)! I will try and get a photo posted shortly
Thank you.
Thank you.
