GPS antenna
Rasalon
 Bay Area CA
I have a march 05 Z4 R. (non Nav)
Does anyone know if there is a preinstalled GPS anntenna? when I was putting in the Ipod addapter I saw an antenna Lead and a possible place to put it into (bolted onto the trunk wall). I have a bluetooth phone with garmin software on it was about to hard wire a Bluetooth GPS antenna when I saw the possible hookup.
Would apreciate any help on this matter. :oops:
Not preinstalled unless you have bluetooth phone kit installed or in the case of the US I think you have a sticker in the trunk that tells you.
The factory location of the GPS antennae is bolted to the top RHS of the frame that holds the Sat nav/CD changer units, between the seats. I know as I fitted one into the OEM bolt holes last weekend.
As an alternative if you lift the lower edge of the carper on the rear bulkhead behind the seats you'll see a central access hole for electics to the cdchanger, sat nav, etc.. You can pop the antenna through and fix it down with double sided tape.
I do have the blue tooth phone kit but I don't have satnav installed. I assume that the wireing harness is still there but not usefull becuse form what you are saying it does not sound like the antenna is bluetooth capable.
I am interested in alternative location you mentioned. can you describe a little better where this central hole is and what color are the wires for power since I'd have to splice into them.
PM sent as you PM'd me the identical questions before I read this post
