T TIMMOS29 Member May 29, 2025 #1 Doing a gearbox fluid drain and was wandering if I should put a new copper crush washer on ? The old plugs seem to not have any joints on them apart from a small rubber one. Cheers Attachments IMG_5293.jpeg 161.5 KB · Views: 170
Rockhopper Senior member Mansfield Site Supporter May 29, 2025 #2 No copper washer on that model. You may wish to replace the bolt though if you have doubts about the rubber seal.
T TIMMOS29 Member May 29, 2025 #3 Rockhopper said: No copper washer on that model. You may wish to replace the bolt though if you have doubts about the rubber seal. Click to expand... I put some ptfe tape round the threads just as a precaution.
S Scooba_Steve Lifer NW London & Somerset May 30, 2025 #4 TIMMOS29 said: Rockhopper said: No copper washer on that model. You may wish to replace the bolt though if you have doubts about the rubber seal. Click to expand... I put some ptfe tape round the threads just as a precaution. Click to expand... I’m pretty sure TIS says to replace but will check.
