Simon 3.2M
I'm going to change both however I can't to seem to find the specs when I do a search - can you guys recommend the oils specs and amount for each please. TIA
GuidoK said:Be sure to first loosen the fill plugs and then the drain plugs (if you cant loosen the fill plugs you have a big problem with the oil drained out)
Bodyboarder said:I’d stick with genuine Bmw stuff .... the previous owner put in millers / something else for the gear/diff ... correct grade and everything . After having my ins 2 done with correct Bmw stuff the gearbox felt very very much better for it . Smoother .
R60BBA said:That’s very interesting![]()
Bodyboarder said:I also had the cdv mod at the same time ... so this could have also had a bearing in it . I have millers in all my other cars , it’s good stuff . Just my experience that’s all![]()
Simon 3.2M said:Both plugs freed up nicely - 20 mins to change the diff oil plus £36 for the actual oil. Indy wanted to charge me £170![]()
I think you may be right mate!mr wilks said:Simon 3.2M said:Both plugs freed up nicely - 20 mins to change the diff oil plus £36 for the actual oil. Indy wanted to charge me £170![]()
Change of indy required too![]()
