Hi,
I recently picked up a 2008 3.0si coupe manual but worried about a noise I’m hearing and getting a little worked up over it. I seen a previous thread detailing something similar but the videos are no longer available to compare. I’d really appreciate if people from here could watch mine (sound more noticeable later in the video) and see if this is the classic gear rollover/input shaft noise that I believe was described as a characteristic?
My last 3.0si I think made this noise but can’t remember. It also chatters slightly on uptake when pulling off. Noise only happens when warm and when in neutral with foot off clutch. If I press the gearstick forward slightly (but don’t engage a gear, the noise goes away too. Other than that, the car drives and pulls without issue, no slipping etc. car is on 59k miles and full BMW history. Original gearbox oil too so will dump this out replace with 75-90 LT3 …. (I think that’s the correct oil for this)??
https://youtube.com/shorts/SVYJkglUPCI?feature=shared
Thank you.
Thank you.
