g power supercharger for z4 for 3000 eur new
spun
 spain
Hi, its not the best supercharger the asa t3 because is on the limit with this kit, but for 3000 euros could be a good deal for 306hp . https://www.g-power.com/benoetigt-de/kompressorsystem-sk-plus-rs-z4-e85-e86-3.0i%20-%20306%20ps_1319.php
Good find. I've been more than happy with my G-Power Z4M. The ASA supercharger is the best centrifugal unit out there in terms of performance. It's lighter and more efficient than a Vortech, but more expensive to maintain in terms of rebuild costs. I wouldn't be put off by 306 bhp. It is similar to the VF kit in terms of boost pressure, and it will likely have more midrange power but less top end.
Personally, I would rate this kit above other non-intercooled centrifugal kits but below the ESS twin screw kits, assuming you don't intend to swap pulleys to adjust boost on the kit. G-Power kits are packaged as the end-all of kits, so they do not expect you to increase the boost and modify the kit. My M kit has zero headroom. Other kits are pieced together with some custom parts, and they typically include oversized superchargers, which is why I was able to modify my non-M's VF kit for higher boost.
Bottom line - great conservative kit that will put a non-M in the same power league as an M. You shouldn't really go much further on an M54 anyway without serious work, but if you want a high boost build, you need to go with a twin screw or Vortech unit.
One more thing - I haven't looked at the non-M G-Power or ESS VT kits up close, but the VF kit is exceptional from a mechanical engineering perspective. It can easily handle more power. So if your goal is to build a centrifugally supercharged car in stages, the Vortech is probably the best choice. I'm at about 320 whp with 144k miles and water/meth, pulley, and tune.
