Fusion 300 Watt Active Subwoofer - Fits In The Z4 Boot!
Exactmax
An excellent condition Fusion 10” 300 Watt Active subwoofer with all original cables to make it work. It is fully working and produces a very good bass sound for such a small enclosure. Being sold as it is no longer being used.
Specification
Max Power: 300 Watts
Frequency Response: 30Hz to 250Hz
Bass Boost (Variable): Zero to +18dB
Low Pass Filter (Variable): 40Hz to 250Hz
Tuning: Bass Reflex
Woofer size: 10 inch Encounter with green cone
Fuse: 15 Amp
Tube Dimensions: 306mm(w) x 306mm(d) x 550mm(l)
Wired remote level control
Finish: Embroidered Fusion logo to black carpet covering with integral chromed grille
Looking for £40 and collection in person from the Redhill area.
You can buy a cable that enables you to add the subwoofer to the existing Z4 radio or you can splice it into the speaker wiring. The bass quality is very good with a deep rumble but its fully adjustable via the controls of the subwoofer. I hope that helps :)
