Fuse box
Timdon
The drivers window and mirror controls have stopped working ,I suspect the fuse may have blown,can anyone tell me how to get into the fuse box without damaging trim :D
When mine stopped working it was a bad contact on the connector to the switch in the door card.
I removed the card then removed the connector, cleaned with contact cleaner and reassembled, ok since.
See if it illuminates as that might indicate a bad earth at the switch.
Just done diagnostic test with Carly and the fault came up as mirror short Circuit ,has any one got a link with door card removal instructions or how too remove them ? :)
I'm about to embark on a permenantly wires dash cam so will need access to the fuse box and I don't want to unnecessarily remove trim.
