Funny gas tank and fuel "problem"
czechT698
 Prague
Hello everyone,
This might seem kind of strange, but I am definately not paranoid. The thing is, the car feels much faster and responsive when the fuel gauge drops under 1/2 a tank left. If the needle is just slightly above or generally above 1/2 the car feels underpowered and lacks the "push" it has when there is less then 1/2 of fuel in the tank. Seems strange, but there you go :o As sson as the gauge needle hits 1/2 tank left the car feels like it has 50 more HP. It is only noticable when engine is restarted. And yes, I use the same brand Shell 95Vpower all the time.
Anyone have an idea what this is?
Weight? Fuel is heavy. Close to 3kg per gallon if you assume UK gallon (just over 2.5 kilos if US gallon). Also varies with blend, but 3kg x 1/2 tank = heavy.
whoah :o Ill do some reasearch and experimenting and will let you all know. Does the Z have one fuel pump or two? Any diagrams of the fuel system? :)
