TH3CROW said:Morning cj10jeeper,
Yesterday I took the car to the garage and the mecanic told me camber in a Z4 is not adjustable. They said its fixed. They told me you can adjust it but not in a "normal" way as you can adjust the toe because apparently they have to dismantle the whole suspension and bla,bla,bla... I thought camber was "easily" modifiable removing a pin on the top with an special tool, am I right cj?
Thank you once again.
Yes front camber is adjustable within the limits of the tolerences in the 3 bolts that mount the strut top. You are correct that you remove the pin, typically to get more camber by pushing the towers inwards.
The guys who did mine said they often have to remove the pin just to get to OEM spec.
