Fuel Pump Removal?
Shipkiller
Veteran
Has anyone here pulled their fuel pump and filter assembly?
I don't mean you had the dealer do it, I mean have you done it, personally?
surely car won't run to good with this mod
ah sussed, its a way of tying to increase mpg, could work well
Not a mod but troubleshooting a hesitation issue on the Roadster. I had a bad no. 5 coil, replaced that but now it has a hesitation on moderate throttle, starting at any RPM.
Going to do a fuel pressure test on the fuel rail to see if that is the issue.
Pvr, no you do not have to drop the tank.
Ed, I have not thought about a TB reset. Have to research that to see if I can do it or have to take it to the stealer...
