This truck was lovingly restored by Big Caddy of VwVortex. During my ownership it has served me well and has been performed extremely well in all aspects. Unfortunately, I must sell this vehicle for other of life's endevours. I will be posting updated pics in the coming days. There are a few things that need some attention such as a torn cv boot and a small ding on the front driver's side fender. As I go through the vehicle I will update the "honey do" list as well. I will be repairing these items but will adjust my price accordingly if purchased before the repair has been made. The vehicle is in excellent running condition and you will be pleased with the build quality of this vehicle as I have.
Engine
2.0 liter ABA block 1996
48,000 miles
Head
87 GLI hydraulic lifter head
Port matched
3-angle valve job
TT springs
TT lifters
Valve Guides
Upgraded Corrado valve cover gasket and studs
Techtonics Tuning 268 Cam
Tension Pulley
Timing Belt
Exhaust
Techtonics tuning down pipe
Techtonics tuning exhaust
4-2 manifold
Transmission
87 GLI transmission 5-Speed (upgraded from 4-speed)
Sachs 210mm Clutch and pressure Plate
Drive axles
Linkage parts
Suspension
Bilstein Heavy Duty front struts
Neuspeed soft sport front springs
Neuspeed lower stress bar
KYB rear gas shocks
Wheels and Brakes
ATS cup wheels (perfect)
Kumho tires
Brake rotors vented
Interior
Reupholstered Corrado Seats
US style Dashboard
Larger MK2 steering column stalks
Jetta 1 door panels
Jetta 1 center console
Oil pressure gauge
Volt gauge
Oil temp gauge
Paint/Body
PPG Audi Aviator Grey base/clear
Painted entire vehicle inside and out
Relocated driver side mirror to front of door
Shaved Passenger side mirror
Shaved antenna
Mounted Fuba on roof
Jetta 1 euro bumpers front and rear
Jetta 1 euro front headlights
Custom grill for headlight conversion
Rhinolining type spray on bedliner.
Painted fender flares and front air dam
Knock sensor installed allowing timing to be advanced 13 degrees
$5,000 obo
Engine
48,000 miles
Head
Port matched
3-angle valve job
TT springs
TT lifters
Valve Guides
Tension Pulley
Timing Belt
Exhaust
4-2 manifold
Transmission
Drive axles
Linkage parts
Suspension
KYB rear gas shocks
Wheels and Brakes
Kumho tires
Brake rotors vented
Interior
US style Dashboard
Jetta 1 door panels
Oil pressure gauge
Volt gauge
Oil temp gauge
Paint/Body
Shaved antenna
$5,000 obo
