FS : M3 Rear Anti Roll Bar + New Powerflex bushings
marksdesigns
 SANDHURST, BERKSHIRE
got a used BMW E46 M3 REAR anti roll bar - sitting here waiting to be fitted, excess stock from previous car. Found it under my desk!
Also i have the correct M3 Power Flex bushings as well, these are as new, unfitted etc.
This is a common upgrade for the Z4 and fits without too much messing around.
£100 the lot.
collection would be preferred as the bar is quite large. im in Sandhurst GU47 area or Maidenhead SL6. Berkshire
thanks for looking. will be on fleabay in a week.
yep it should fit ok.
all the bars are roughly the same shape, just a different thickness. the 2.2, 2.5, 3.0 all have a 18mm bar, with a small bushing and small support. The M3 and Z4//M has the larger 21mm bar.
maybe you would need to change the support - this is on real OEM...
03 STABILIZER SUPPORT 2 33556780707 $2.22
for a minimal amount. that support will hold the larger bushings. should be good to go.
*** certainly a great mod for the guys with 3.0si etc. :thumbsup:
I have the front one on mine it made a nice difference. But the diffs are different obviously the M3 has a LSD.
And there are cooling fans on the back of our diffs that seem to be in the way? I don't think its just a straight swap like the front. The m version is very straight where as ours ( mine defiantly ) Has a bend to clear the diff cooling fans.
i think MrLozzer did the front and rear conversion on his 3.0, seem to remember seeing the bars powder coated etc. hmmm. will see if i can dig that out.
I brought his off him he never got round to fitting them Mark.
Sorry i really don't mean to pee on the fire hear. I am just not sure they fit! The front yes i have done it the rear wont on my car.
