FS: Eventuri for Z4M and 3.0si N52
ba3bas
 Barnet
Due to a change in direction I will be selling my eventuri with fittings for the 3.0si N52
If the 2.5si has the same intake boot then this will also fit.
Basically as long as the airbox inlet is the same size it will fit.
The parts required to fit the maf where made by Eventuri as a one off and plenty of development and testing was involved to get it to fit but more importantly run with CEL or a requirement for a map.
After months of testing and many miles put on, I can confirm no issues and only positives.
Plenty more pull from the engine, so much more classy noise from up front.
It truly is epic
As the car is being worked on now, I don't have the unit with me but I will be collecting my car from kings Lynn soon so if you are interested I can drop it off if you are on my way home to London.
Price for the eventuri, maf boss, hoses and clamps £550
Looks good, do you notice any flat spot in the revs using this as I've heard the airbox on the si is pretty optimal.
Also where abouts are you in London as I'm not really on your way back from there (west Herts)
Cheers.
Cheers.
No flat spots at all.
When you gun it, the revs climb uniformly.
I'm in North London
Price change £550 as I didn't realise evolve changed prices.
Please note if you want this for the s54 you just need a maf boss from eventuri which I'm sure they will send foc.
I believe I still have the one the came with the kit so your welcome to have it until you get a new shiny one
