Thought I would put these up here before they go on ebay tonight. Anyone interested, PM me. Andy
Prices INCLUDE P&P
GUNSON COMPRESSION TESTER
£20
http://www.gunson.co.uk/items/pdf/Products/G4101_Instructions.JPG
Product Description
• Hi-gauge is a tool for measuring and recording the pressure created by the piston in each cylinder.
• This information is used to diagnose faults in valves, pistons, piston rings, cylinder bores or head gaskets.
• Such tests are an excellent guide to general engine condition and can be used during routine engine servicing to give advance warning of developing problems or for fault diagnostics.
• Calibrated in BAR and Psi, suitable for petrol engines with 14/18mm spark plug ports with flexi hose for easy fixing.
LASER IGNITION SPARK TESTER
£10
Product Description
• Ignition Spark Testers for testing the output on HT leads.
• Fits over the top of spark plug
• HT lead plug into top of spark tester
• Spark Tester will flash to indicate ignition circuit is working
• 4 Spark Testers per pack
Instructions:
1. Always remove and refit each HT lead in turn
2. Fit tester between HT lead and spark plug
3. Start engine and observe testers
4. If the testers flash in sequence and the engine still runs poorly, then the problem may be that spark plugs or fuel lines are fouled
5. If one of the testers does not flash, the problem may be with the rotor arm, distributor cap, ot the HT lead to the suspect plug
6. If all the testers do not flash, the problem may be with the coil supply, distributor, contact set, or coil HT output lead.
BLUE HAMMERITE METAL PAINT (FOR BRAKE CALIPERS)
£5
New Blue Hammerite Smooth Finish 250ml Tin
Product Description
Hammerite Smooth Finish Colour: Blue Size: 250ml A High Gloss Finish - That Is Specially Formulated To Form A Tough Barrier That Sheds Moisture To Provide Long Lasting Decoration And Protection.
• Decorates Protects And Rejuvenates Metal
• Incorporates Advanced Silicone Technology
• Corrosion Resistant
• High Gloss And Colour Retention
• Can Be Applied Directly Onto Rusty Metal: No Need For Primer Or Undercoat
• Quick Drying: Touch Dry In 30 Minutes Rainproof In 1 Hour
DRAPER TORQUE WRENCH
£20
Used draper torque wrench complete with case. Full working order.
Product Description
Draper 30357 (3001A) 1/2" Square Drive (40-210NM or 30-154LB/FT) Ratchet Torque Wrench.Features:
• Reversible ratchet head
• The lb-ft and Nm scale is engraved on the barrel of the wrench
• The micrometer type sleeve allows accurate preset torque values to be set
• When torque is reached the wrench produces an audible click and a release of tension.
• Comes with:
• Blow moulded storage case
• Torque: 40-210NM or 30-154LB/FT
• Marked range: 30-210Nm/22.1-154.9lb-ft
• Overall length: 475mm
• Shipping Weight: 2kg
LASER MINI PUMP
Laser Multi Purpose Mini Pump Brake Fluid Gearbox Differential Oil 4385
£13
Product Description
Handy mini pump makes all top up jobs easy./p Ideal for gear boxes, differentials, lawn mowers, chain saws, outboard motors and suitable for oils, automatic transmission fluids, brake fluids and general purpose cleaners.
One litre capacity with 0.13 oz per stroke
ELECTRICAL IMPACT WRENCH
http://www.amazon.co.uk/Liftmaster-Impact-Digital-Display-Configuration/dp/B0036YHBMM
£30
Product Description
• Power Source: 12V cigerette lighter plug or battery connector, 4m Cord
• Standard 1/2" Socket Shaft
• 3 digits torque display and settings
• Sockets: 2 x double ended 1/2" socket covers 17mm 19 mm 21 mm 23mm nuts
• Min Torque 80N*M; Max Torque: 350N*M (258 ft*lb)
Prices INCLUDE P&P
£20
Product Description
£10
Product Description
Instructions:
£5
Product Description
£20
Product Description
• Comes with:
LASER MINI PUMP
£13
Product Description
£30
Product Description
