Hi all,
Been experiencing steering issues with the Z4 which I understand are quite common after doing a lot of research. On my non RFTs, at higher speeds and particularly on smooth roads the steering goes light and requires small corrections to keep in a straight line as the wheel seems prone to making its own small adjustments left and right.
I've just had an inspection done which has pointed out "front wishbone bushes perishing" among other things for me to tackle. Research has shown these bushes to be a common problem and after replacement this resolves the issue I am having.
Please could someone confirm I've bought the right parts to fit? These are the "lollipops" with the bushes already in?
What other tools will I need to change these?
https://www.carparts4less.co.uk/p/lemforder-control-arm-wishbone-bush-618110295
Thank you!
Chengy
Thank you!
Chengy
