Front wheel bearing nut size?
sk93
Veteran
 Nottingham
Hey hey.. time to change up one of my wheel bearings.
Question I've got is - what's the size of the nut holding the bugger on (as I expect I'll need to be buying one)?
Cheers,
Ian
I have a large metric adjustable spanner if you need it. I keep it next to my skirting board ladder by the sky hooks??? :?
cheers - but I've got one too.
I just doubt it'll fit (the bolt, I think, it quite sunk inside the bearing flange).
Plus, I'll need to torque it back up after :thumbsup:
ok - i ordered a 45mm one, as nobody knew.
turns out I was right. it is indeed a 45mm socket.
But you need to be wary on the width of the socket, as its a tight fit. :thumbsup:
