Broken coil spring on 2011, 35is. Seeking advice on removing strut. Circled area in pic shows cable going into strut. Not wanting to push or pull or twist something that doesn't want to push, pull or twist, how do I separate this cable from strut? Hoping strut is still ok although what appears as leakage is a little concerning. I did use wd40 on bolts, but if strut needs replacing, do they all have same location for said cable to be "plugged" back in position?
