front roll bar bush size ?
Chaps
Quick one , I'm driving a e85 2005 2.5 and will be replacing the front roller bushes this weekend . Ive noticed a few different sizes 24mm 25mm 27mm . Any ideas which is for me and can you recommend a type . Also going to replace the drop links and might pluck up the courage to do the control arm bushes . Ive a wee knock on the drivers side over road bumps .
thanks
http://www.carparts4less.co.uk/performance-bushes
Cheapest place I've found them and they sometimes have a 10% discount code so handy if your not in a rush.
Check whether your car has M Sport suspension using a VIN decoder and then order 25/19 if it does or 24/18 if it doesn't.
