Front right indicator
1doohan
Hendon...N.London
Had a yellow beacon of despair light up my dash for last 2 days wondering what it could mean. Last night driving noticed the front right indicator on permanently solid colour. Works fine when used along with hazard lights...but just won't go out. Ideas on a postcard please.IMG_20190401_210941223.jpg
Probably on because of the bulb failure. Check your side, dip and main beam in that headlight.
It’s BMW way of telling you where the fault is.
Stuart
Solid indicator will be due to a sidelight. Even if the bulb works the system may be detecting it is on its way out. LEDs will also cause this. Checks can be coded out.
Houston...we have found the problem (thanks to Steve+ Stuart)
