Front Jacking question again!!
TIMMOS29
Im trying to get my head round an easier way to get the front of the Z on jacks on the jacking points. I havent got a central jack point on mine so cant seem to figure out an easier way to do it...
Ive got an pneumatic jack so its fairly easy to lift the car.
Jack it on the rear cill jacking points, it’ll lift the front high enough so you can get an axle stand under the front jacking point.
ok thanks alot
Could i then go round the other side and do the sane thing? Or would it be unstable!?
I lifted one side on the jacking point and when the other side was high enough I popped the axel stand under it then let the jack down and put the jack under the bottom ball joint as it was up in the air and jacked it up high enough to get the axle stand under the jacking point.
