I checked the bulbs they look fine. I checked Fuse 36 look fine to.
Rear works fine.
Nothing happens on the front no light on dash.
There is condensation on lense but the bulb housing looked ok no corrosion.
Any ideas?
yes that would be the next step, the relay is behind the fuse box.
If you switch the fog lights on and off and listen carefully you should be able to hear the relay clicking !If it's clicking at least you know the switch is OK ! good luck
