Front central jacking point for axle stands on NON ///M?
Ducklakeview
Merseyside
Had a search on the forum, for this, but if I am reading it correctly, it's only the ///M that has this? A brief look under mine and I can see some sort of "black squareish" shaped area in the middle just forward of the wheels, is this not a jacking point? I ask as although I have a Costco low trolley jack and axle stands etc, if I use the side jacking points to raise it, I cannot get the axle stands under them, unless there is another "proper" position for the stands?
Whilst I'm on the subject, am I correct in assuming I can raise the whole rear using the bracket under the diff where the two struts meet?
Mike
No central jacking point on non ///M. If you jack on the alloy brace/cross member you risk bending it unless you put load spreading timber under it
Jack at the front sides and place axle stands under something solid like rear front wishbone mounts
Rear OK as you suggest
