My current geometry is 0.02 toe front, 0.04 toe rear, 1.25 front and 1.5 rear.
I find it is lacking turn in and my H&R ARBs are the only thing making it slightly oversteer on a long radius corner, but not in a good way as the rear is too stiff and it's losing grip. I've actually gone from full hard back down to full soft after trying all sorts of permutations but with stock suspension anything harder just results in a sudden transition into slip.
My question is, for those who have pulled the front camber pins and pushed it right over what camber did you get and did it increase front end grip? I'm loathe to spend £50 (toe will need doing again too) if it's only likely to be 1.3 or something.
Thanks!
Thanks!
