Front camber adjustment
Hi,
Can anyone point me in the right direction with this??
I fitted my Eibach springs, and all is well, but I have noticeably more camber on the passenger side than I do the drivers side.
I know there is camber adjustment at the top mount, but my adjustment pins are still in place. Is there any movement at the bottom?? I assumed that because the struts are bolted to the hub in the way they are that there is no adjustment, but am I correct in that assumption??
Pull the pins and adjust the camber I think I had mine adjusted to 1.3-1.5ish.... You can generally get a bit mor if lowered or depending on the tolerances of the components from car to car :)
I also have zero toe in and found the wear is a lot more even although it tram lines slightly more.
