Good afternoon everyone. Thanks in advance, any input is useful.
BMW E85 2004 SMG. Ran smooth as silk until recently. To make a long story short, I tried to start it yesterday. In the little window where the current gear is shown, a FN code appear. Couldn't switch gears or start it for a while. After a few tries (switch on, try to shift from first to neutral, switch off, take out key, repeat process) I was able to get it to N and start it. Let it run for a few minutes, took it for a spin, came back home.
Today, same thing happened. I am not moving the car, because I don't want to be stranded outside. I believe the culprit may have something to do with the shifting sensor.
So here are my questions:
1) Do you guys know what the "FN" code in the gear window stands for?
2) As you can tell, I am no tech expert. I don't want to take it to the dealer, becasue down here in Mexico, I might as well just scrap the car, dealerships are really expensive when diagnosing. What kind of scanner/process should I look for with and independent mechanic?
Any other thoughts are really appreciated!!!
