Hello all.
I've tracked my clunking and vibrating driveshaft woes to the flex disc.
My local garage are going to put it up on a ramp and check, but I'm confident this will be the issue. I'm going to order the part for them to fit, and a search on other forums seems to indicate that I an fit this part:
FEBI BILSTEIN 43466
It's apparently OEM.
My question is, is this correct? Also do you advise I buy the part, or let the garage sort it. The FEBI one is about half the price of others I'm seeing online.
Thank you 8)
FEBI BILSTEIN 43466
Thank you 8)
