jnwright71
Hi All,
I am now the proud owner of a mint condition wind deflector and full fitting kit (brackets for both the roll over hoops and boot lid) courtesy of handy_andy_100 who is sadly breaking his car. I thought fitting this would be a simple process, but having read up on the subject, there appears to be three approaches:
1. Buy new roll over hoop covers (with the holes cut out), fit these and simply screw the brackets into place.
2. Drill the existing roll over hoop covers to expose the screw threads, then screw the brackets into place
3. Drill very small holes into the roll over hoop covers, then use short self tapping screws to secure the brackets in place
If I understand things correctly, option 1 is the best method, but will add another £120 or so to the cost which I want to avoid. Option 2 sounds like the most risky, but if careful will deliver the integrity of option 1. Option 3 is the most cost effective and others have done this successfully.
I would like to pursue option 2 or 3, but am a little reluctant to start drilling without clear instructions. Thus does anyone have the exact dimensions regarding where holes should be drilled (photos would help enormously), the size of the holes, the size of screws (option 3) etc.
Many thanks, James
Many thanks, James
