as I'm installing a couple of gauges i thought i would put some pics of the install up, forum has been very helpfull so i thought i would put something back for others
its not easy to see what your doing on this engine and it took a while to locate the plug, i found removing the aloy heat sheild from over the exhaust allowed a good view of the plug and more room fro the socket, you need to remove three M8 (13mm socket) and one M6 (10mm socket) to take the shield off, its a bit tight and you have to push and pull some of the other shields but it will come off.
ones its off you get a good view of the plug and you need a 13mm socket on a 6 inch extension to remove it, if you have the sensor ready and close at hand you can fit it back quickly without loosing too much coolant.
this is what you remove
IMG_0888[1] by oxhouser, on Flickr
i assembled the sender unit into an adapter to take the 1/8 npt sender to M14 x 1.5 and used a 19mm 5 1/2 inch box spanner to put it back this allowed the wires to sit inside the box spanner
box spanner
IMG_0887[1] by oxhouser, on Flickr
fitted to socket set
IMG_0889[1] by oxhouser, on Flickr
sender in position, this cant be seen with heat shield in position,
IMG_0886[1] by oxhouser, on Flickr
hope this helps
box spanner
hope this helps
