FItting a reversing camera
mcbutler
Veteran
 Plymouth
Hello all,
For those of you who have retrofitted a reversing camera.
I plan on mounting mine above the rear licence plate, can anyone advise on the best route for the camera cable and point of entry from outside to inside the vehicle?
Thanks in advance
Mark...
There is a bung behind the rear bumper on the right side, it has the numberplate lights loom (and PDC if you have it) going through into the area for the roof module polystyrene box. From here I run along the right side, through the hole in the bulkhead, past the right rear speaker, down along the drivers (right) door sill, up and over the steering column and into the rear of the headunit area (or to wherever you need the cable to go.
Power supply - I'd tag off the reverse light and through one of these...
This smooths out the signal and gives you a steady picture for the camera :thumbsup:
