Since it is bonfire weekend I thought I'd make the most of the cover of late night explosions by beating the living p!ss out of a spacer for several hours.
It's a 10mm hubcentric spacer on the left rear axle of my Z4MC. I'm trying to remove it to fit wider wheels with more aggressive offsets. The right rear came off with a heat gun and a couple of taps. So far on this one I've tried:
* pulling it of normally
* several healthy whacks with a mallet
* heat gun and then the above
* heat gun and then thin flat head screwdrivers hammered into the side
* blow torch then more whacks
* blow torch then screwdrivers
* blow torch then a claw hammer, hooked inside the extended hub like a crow bar
All the while soaking liberally with WD40. Going to bed now - pretty annoyed. There wasn't a smudge of anti-seize behind the one that came off so I'm guess that the remaining one is fused solid. Any hope of saving this spacer is gone now - it is thoroughly smashed!
Any more ideas? I guess I could cut the thing off with a dremel or angle grinder. I might buy some PB Blaster - people seem to rate that over WD40. Could also try spray-freezing the rotor before blow torching the spacer, or tapping some oversized bolts into the lug holes and using them to drive it out some how.
Grrr... 1am!
Grrr... 1am!
