I had fitted b4s suplex springs and lemforder top mounts,had the exact same set up on the fronts done about a month ago done by the same guy with good results.Dark Diggler said:Which dampers did you have fitted Swanny ? I used b4 and a new bolt (from bmw and identical to the one that came out), it all snugged up and torqued up with no knocking at all, having done mine myself I’m not sure I subscribe to what the guy who did your work said to be honest. I could be wrong but I would think there’s a good number of folk on here that have fitted bilstein without issue.
I’m glad you’re sorted now though and able to enjoy the way your car now feels, have you had 4 wheel alignment done too?
I have also used the same guy for other jobs always with a good end result so i am a little confused myself.
Regarding alignment I had the fronts done when i refreshed the front but yhe guys with the hunter set up said 3 bolts on the rear were too risky to try undoing,however when i had the rear suspension done the mechanic on my request freed up yhe bolts so i can now have it all aligned.
But all is good now so in the end all is well
