Just used Carly to check for faults, and found fan motor - 2EFE.
Now I assume this is the radiator fan.
What should I be testing to check that it works?
Can you use Carly to force it to run?
Is the fuse/relay in the engine bay?
I remember someone having an issue with the connector at the top of the radiator and needing re-crimping. Do I need to take the radiator cover off to get to this connector?
Luckily my drive to work is normally free flowing so no risk of overheating yet!
