matsmith749
B21 said:LCI is not an issue as there were no specific changes at LCI time apart from minor plastic trim on the dashboard, the later side repeaters which can easily be retrofitted if fussed and LED DRLs which again you can achieve the same effect with LED bulbs instead of the halogen H7s.
You can't.
For some technical reason that is beyond me, changing the angel eye bulb to a white LED version is better than the pure yellowish tint, but the halos are very different brightnesses.
The LCI headlamps look way better in real life - very crisp bright even output (plus an eyebrow). I didn;t manage to get anywhere near a similar result with my non-LCI lights & tried a pile of different LED bulbs.
I get that most people wouldn't care - but it's something that once I had seen the difference meant I was no longer happy with the pre-LCI angel eyes (even after I did the LED upgrade).
I wouldn;t go buy an LCI car just for the headlights (duh) - but if I was shopping for a 2012, I would certainly look to stretch a little further & shoot for a 2013.
