Zed_Steve said:The charger for my TomTom does go into the socket, but the connection isnt great. Sometimes need to twist it around for the light to stay on.
Fairplay Klarky, but if you are going to hardwire accessories in just be aware at what and where they are fused. I think most ciggy lighters are fused at around 15 amp but am not sure if tom tom chargers and the like fuse down upstream of the point of plugging in. Anybody got any ideas ?klarky said:very true - you'd think they would go to usb or something similar for a 12v feed. at the moment im sorting out hardwiring connections for my tomtom and snooper, basically tapping the fag lighters supply and soldering some wires
I guess if push comes to shove and your not going to use the lighter socket for charging the lighter itself (quite a load) you could quite easily drop the fuse in the fusebox to a 5 or 3 amp perhaps because it will be on a dedicated circuit,I am fairly sureklarky said:yeah its something im looking into, the snooper i bought has a hardwire kit with an inline fuse so no worries there, the tomtom im looking for a similar cable.
Do you think thats a default setting or is one of those choice things that has to be enabled by the stealer ?Voodoo said:A conversion to two usb connections in place of the normal 12v cigarette lighter is a great idea. I wonder how tricky it could be.
Also to note, I've just done a little test and the ciggy lighter socket stays live in excess of one hour after the ignition is off, key out and door locked.![]()
Mik said:Do you think thats a default setting or is one of those choice things that has to be enabled by the stealer ?Voodoo said:A conversion to two usb connections in place of the normal 12v cigarette lighter is a great idea. I wonder how tricky it could be.
Yeah mate.. I guess the best thing to do is try eh? Infact I ll go down to the garage and check it out right now !Voodoo said:Mik said:Do you think thats a default setting or is one of those choice things that has to be enabled by the stealer ?Voodoo said:A conversion to two usb connections in place of the normal 12v cigarette lighter is a great idea. I wonder how tricky it could be.
I'm afraid I have no idea, though I would say that it's a default setting that can't be adjusted if I was to take a guess as I've not seen it on any of those programmable options lists that appear from time to time.
Voodoo said:Steel,
Have you pushed the plug fully home (i.e. past a bit of resistance)..?
When I plug my TomTom/phone charger/iPod adaptors in, they meet some resistance when they're almost fully home, but then an extra push sees it fully in and quite tight (no sniggering at the back!). I have no connection issues once fully home. :?
