Facelift headlight adjustor replacement
philipw
 Bristol
In case any of you run into the same issue as me where the adjustor cogs for the headlight end up falling off and getting lost. There is an option to obtain replacements cogs as the adjustor set-up is the same as the facelift E39.
This Ebay seller is selling the cogs as part of a kit. Installed today and it works again, which is a relief!
https://www.ebay.co.uk/itm/324334814761
Glad to hear it, a replacement light needs to be avoided!
Mine fell off due to incorrectly adjusting it too far, causing the cable to retreat into the housing and the adjustor fall off to be lost forever! Arm was removed from the headlight by undoing the screw highlighted and winding the cable out to allow the cog to be bashed on. All good now:)
