I stripped a pair a while back. Took about 20 minutes each to soak them in hot water then ease the two halves apart. Scrubbed what little remained of the plating off, rubbed them down and painted the insides black. Then fitted £4-worth of LED DRL strips and popped them back together.Street said:I had a set where the internal chrome plating had corroded and looked like sand.
Trying to separate them cleanly was a job and a half and I ended up giving up. Others may have more patience.
Perhaps a better option would be to use these to test colour coding the outside to match the body work. A simple swap back if it’s not for you.
I already have another set to do.pvr said:You want another set Martin? Put in an offer of £0 and they are yours :lol:
enuff_zed said:I stripped a pair a while back. Took about 20 minutes each to soak them in hot water then ease the two halves apart. Scrubbed what little remained of the plating off, rubbed them down and painted the insides black. Then fitted £4-worth of LED DRL strips and popped them back together.Street said:I had a set where the internal chrome plating had corroded and looked like sand.
I was only making light of it.Street said:enuff_zed said:I stripped a pair a while back. Took about 20 minutes each to soak them in hot water then ease the two halves apart. Scrubbed what little remained of the plating off, rubbed them down and painted the insides black. Then fitted £4-worth of LED DRL strips and poppedStreet said:I had a set where the internal chrome plating had corroded and looked like sand.
Perhaps a better option would be to use these to test colour coding the outside to match the body work. A simple swap back if it’s not for you.them back together.
Smarty pants, I must have had a super rare super glued set then![]()
enuff_zed said:I was only making light of it.Street said:enuff_zed said:I stripped a pair a while back. Took about 20 minutes each to soak them in hot water then ease the two halves apart. Scrubbed what little remained of the plating off, rubbed them down and painted the insides black. Then fitted £4-worth of LED DRL strips and poppedthem back together.
pvr said:Where abouts are you? Just need to find a way of getting them to you
pvr said:That is 2 hours away from me (Sussex). Can post though
pvr said:Ok Fred, however I have agreed to post them to meds (assuming the post office does not think that the white powder is either drugs or anthrax :lol: )![]()
