F/S Anti-Roll Bars 3.0 M sport Z4 SOLD!!
dario
Site Supporter
After the passing of my 3.0 e85 Z4 i have available a set of front and rear anti-roll base off of that car.
it was a 3.0 se with Msport suspension upgrade.
These were on the car for a couple of years after which they were removed and placed in the garage loft.
excellent condition and available for best offer over £75.00
delivery / collection available dependant on location.
pm me please
Does the M Sport kit offer much of an improvement over the standard roll bars? And, more importantly, does anyone know whether they will fit a standard 3.0i (2003) running Eibachs?
Contemplating fitting polybushes all round so thinking these may be good to do at the same time... any advice?
Ok, I've just measured the bars.
front is 25mm and rear is 19mm,
If you check your bar diameter and see the difference.
if they are larger than yours, it will improve the roll stiffness on turn in.
its probably more noticeable if these war ego be fitted to a 2.0 or a 2.5 and i believe that they did have smaller diameter roll bars.
I just don't have access to the technical data.
Dario
Thanks for checking that Dario! I can't get underneath mine to measure it, but according to realoem I think the 3.0i front anti roll bar was 24mm (25mm for M sport) and the rear was 18mm (19mm for M sport). I don't know how much improvement that would make, but I'm guessing at least some, otherwise they wouldn't have offered it as an upgrade? :wink:
Would you consider sell it separatelly? I am interested on the front one only (I already have the rear one).
peddy said:
I thought all 3.0 came standard with M sport suspension?
It too long ago for me to remember.
However for theses considering this set of ARB's please note that the front bar is 25mm in diameter and the rear bar is 19mm diameter.
if you are looking for an improvement in handling / roll stiffness, then please check the diameter of your anti roll bars before purchasing these bars.
Dario
