Exhaust trims 3.0si
Chris89
 Sutton Coldfield
I have the standard 3.0si exhaust trims that are looking a bit worn. I have not yet used auto sol or similar as I was unsure whether it would completely remove the finish.
Has anyone had any experience refreshing the standard trims?
Autosol will certainly clean them up a treat, but it really depends how badly corroded the surface is though.
You could always get a nice new custom made set of shiny tips http://www.z4-forum.com/forum/viewtopic.php?f=7&t=60853 :thumbsup:
Thanks for your reply, they are like a rough black around the tips.
I had seen MM's topic however I do like the inward rolled OEM look hence an attempt to refresh my current ones.
This is mine done with auto soul, 50/50s so you can see if it is like yours:
If your up for it, you could always have a go on the back box, it comes up a treat :D:
