Exhaust Specialist. Surrey/Hampshire/Berkshire
beanitos
Hi all,
Looking to get an annoying exhaust vibration resolved which will probably require a decent specialist to sort.
Does anyone have a recommendation within a reasonable distance from Camberley?
Much appreciated
Thanks I've heard good things about TWG.
I have an aftermarket exhaust already, if it needs any new sections fabricated are they able to help with that? That's the only reason I didn't go straight to them.
It's a stupid vibration and after removing literally every piece of trim from the boot I've concluded that it can't be anything other than exhaust related!
I have recently used a local exhaust specialist under the Powerflow name. I believe they are rolled out across the country. Had a cracked middle section which was repaired by cutting out bad section and welding a new piece in place.
OK cheers Tony. I know of Powerflow, I think they are franchised so you probably get good ones and bad ones.
I've spoken to TWG and they suspect just a bracket but it's two weeks until they can fit me in.
I'd try http://www.profusioncustoms.com in Colnbrook
EDIT: Have a look under the rear of the car by the diff and there are 2 diagonal brace bars, I bet you one of those is loose.
EMP Performance
Probably one of the best in the country, take a look at there instagram page for some examples of there work etc.
Ash
Excellent suggestions. Thanks Everyone.
Mister T - I'll be straight on that at the weekend. It's probably going to be dark by the time I get back from work.
These?
These?
Yup, that's them. They bolt up in a few places, worth checking first.
Probably a bit far from you but Mr Exhaust in Reigate were recommended to me by my local MOT station and they did an excellent job on cleaning up the front flange and replacing those infamous exhaust bolts.
