Piper1 said:
Did you by chance order the correct one
First thing I did was double, triple, and quadruple checked I had the right PN for the box and Y pipe for my year and motor as I new there may be some differences with the pre/post face lift variants.
To be clear, it did "bolt in". Everything "fit" (hangers and all) but it was the aesthetic fit that had issues - it hung nearly an inch too low which looked silly, and hit a kerb on the first drive. I initially thought perhaps the hangers were knocked during transit but the guys ended up not being able to simply bend it and had to actually cut and shorten the hangers.
I suspect that the hangers were welded too high up on the box itself during manufacture - there's just no other reason really. That or perhaps they used the wrong bits when making mine, or even sent me the wrong box, with the right labelling - though from your pic, mine looks very much the same.
How mine sat initially (all hangers/mounts fitted with no modifications):
A far cry from what I expected based on Supersprint's picture:
I spent the next morning under the car and found that even if I (using a jack), pushed up against the muffler to sit it higher, I would need to be compressing the rubber mounts by a significant margin (my first suspicion was that the mounts were worn or stretched). However they looked fine and compressing them by nearly 50% didn't make sense.
I also fiddled with in/out, left/right, rotational position to see if that would affect where the hanger sat in the rubbers but nothing could make up the huge difference in height.
When I finally took it to the exhaust shop, they rechecked the install (that I had done at another shop), and it seemed fine. The Y pipe was fine and there wasn't really any adjustment there to be made - in case it was a matter of "tilting" the ends.
In the end, they heated up the right side mount (the one with the 2 bolts) and flattened out the bracket's shape which lifted that side higher, and chopped the left hanger and rewelded it. Still could not get it tucked in as much as Supersprint's reference image as I wanted to leave a little bit of clearance from the swaybar mount but I think it looks aces now anyway
Adjusted (higher maybe 2-3cm? I haven't been bothered to measure
It wasn't a big deal for them (didn't cost much) and overall I'm happy with the Supersprint because the tips look great, and it sounds awesome.
