thecookie125
Has anyone got one they've removed or are going to be removing soon? Need more noise from my coupe and thought I would try here before I go book in for a custom one
idej_z4 said:I'm going to be removing mine in the next couple of months, depends how quickly you want it.
Nick W said:Don't know where you are but I have a set of straight quad pipes for an E85 M Roadster down near Plymouth you could come and try. They sound awesome but mostly hang in the workshop to remove the constant drone from the passenger seat.
Straight pipe / backbox delete - custom job.thecookie125 said:idej_z4 said:I'm going to be removing mine in the next couple of months, depends how quickly you want it.idej_z4 said:I'm going to be removing mine in the next couple of months, depends how quickly you want it.
What have you got out of interest?
idej_z4 said:Straight pipe / backbox delete - custom job.thecookie125 said:idej_z4 said:I'm going to be removing mine in the next couple of months, depends how quickly you want it.idej_z4 said:I'm going to be removing mine in the next couple of months, depends how quickly you want it.
bazza190 said:I had the centre box removed. The backbox delete can be a bit too much for some. Worth considering.
I have a custom delete fitted (unfitted?) on my new zed that will be coming off as soon as I can get hold of a standard back box to replace it (which will in turn become slightly modified)...thecookie125 said:Has anyone got one they've removed or are going to be removing soon? Need more noise from my coupe and thought I would try here before I go book in for a custom one![]()
Sidewaze Samm said:I have a custom delete fitted (unfitted?) on my new zed that will be coming off as soon as I can get hold of a standard back box to replace it (which will in turn become slightly modified)...thecookie125 said:Has anyone got one they've removed or are going to be removing soon? Need more noise from my coupe and thought I would try here before I go book in for a custom one![]()
Potentially... what model zed do you have, pre- or post-facelift?thecookie125 said:Sidewaze Samm said:I have a custom delete fitted (unfitted?) on my new zed that will be coming off as soon as I can get hold of a standard back box to replace it (which will in turn become slightly modified)...thecookie125 said:Has anyone got one they've removed or are going to be removing soon? Need more noise from my coupe and thought I would try here before I go book in for a custom one![]()
Would you fancy a swap for a standard box?
Sidewaze Samm said:Potentially... what model zed do you have, pre- or post-facelift?thecookie125 said:Sidewaze Samm said:I have a custom delete fitted (unfitted?) on my new zed that will be coming off as soon as I can get hold of a standard back box to replace it (which will in turn become slightly modified)...
EDIT: it's ok, just realised your post says it's a coupe :headbang:
I'll PM you
