Excessive road noise on passenger side.
javis20
 Hershey, PA USA
I had occasion to be in the passenger seat, when my wife drove my 2011 e89. The road noise is drastically louder on that side. Almost sounds like there is no insulation between my ear and the tire.
Anyone else experience this?
From the driver’s seat I find the road noise is definitely louder from the passenger side rear and my wife also says the same from the passenger seat. Don’t know why though.
Remember that the passenger side is generally adjacent to road furniture, garden walls, houses etc. All of these reflect tha noise the car makes back at you. You dont generally get this on the drivers side.
Another reason can be an ill fitting door/window on that side
Think your right with the way the sound is reflected.
I have noticed the same thing on my e85 and i am confident everything fits correctly on the car
Yeah its really obvious in most cars once soemone makes you aware of it, my daughters in new car sales we mooch around in all kinds of motors, they all do it..
Don't agree. I'm getting this loud road noise even on open highways with nothing on the passenger side, but open fields there, to reflect sound.
Well then its possibley one of the other things mcbutler pionted out poor fitting door,window or maybe the door seal
To me it sound like it's coming from the seat belt retractor area. Right behind my ear.
I'd just solve this by telling her to get out of the car, turn up the tunes, and then drive myself. There are multiple types of noises from the passenger seat. :P
Nagging mostly about going slow in the bendy bits :D
I noticed the same with mine when I bought it, not investigated that yet as I tend to have the tunes cranked up, however, will do at some point. I’d say a seal or window/door fit issue.
Well I got to the bottom of the excessive noise problem. Apparently the rear tires are cupped on the inside edge, the right rear wheel is bent and the differential is worn and leaking. At this point I'm planning to just buy a new rear differential for $2000 and have an indie install it. In the mean time I'll find a 2nd hand wheel before replacing the rear tires.
:thumbsdown:
Quite a combo :tumbleweed:
Maybe get a second hand diff and get a LSD put in for the same money ?
